Offset Nulling for BUF03 Buffer
Hi
I plan to use an AD/PMI BUF03AJ/883 Buffer in the Input section of a High-Pass Alignment Filter to drive the filter with very Low impedance so that its Q is strictly maintained.
The BUF03 has Trim offset adj using Pins 1 & 5. A +ve supply with a 5k trimmer is to be used as per the suggested circuit. Could members kindly outline
How to null the offset of the BUF03 and what all needs to be done to achieve this?
Thanks in advance!
~Arup
