Ok, Some 16 years ago when I had the age of 16 and had no Idea about T/S specs of a speaker I got these 15" speakers for not to much money.
I used them in a BR enclosure I had build using online plans but tuning etc.....I didn't know.
It worked "OK" but wasn't perfect either.
So I still have these woofers lying around and was wondering what to do with them......
I recently got me a DATS measuring device so first thing I did was measure the T/S parameters.
This is what I got.
Re:7.691ohm
Fs:40.38Hz
Qts:0.8199
Qes:0.9743
Qms:5.174
Le:1.183mH
Mms:132.4g
Vas:135.8L
SPL:91.52
So looking at these they are a little strange. Qts is rather high.
Even for use in a closed box.
So what would you guys recommend when using this woofer?
Maybe I could do a little experimenting with MFB.....?
They are said to handle 400w but It's a little optimistic I think.
This is what I got.
Re:7.691ohm
Fs:40.38Hz
Qts:0.8199
Qes:0.9743
Qms:5.174
Le:1.183mH
Mms:132.4g
Vas:135.8L
SPL:91.52
I like these specs for TLs, so ~Fs/Qts = ~ 49 Hz tuning before stuffing and of course some prefer OB. The downside for both though is that they probably are low Xmax, so very limited peak SPL down low.
GM
GM
Thanks,
I'll have to look at it for some time to get everything.
Never tried a transmission line as a sub so this looks interesting.
I think they would make dandy OB helper woofers. With a decent size baffle (not huge) They should do nicely down to the low E on a bass guitar and a bit lower. Another possibility would be as part of an in-wall (i.e. infinite baffle) setup just don't expect true subwoofer output levels; Good for the mains though.
Some sealed sims...
Red line is about 10 ft^3 while grey line is about 14 1/2 ft^3.
A true infinite baffle (rear of driver exhausts into the next room)...
You could try an aperiodic vent too.
Some sealed sims...
At higher power levels, the effective value will be a bit lower.I recently got me a DATS measuring device so first thing I did was measure the T/S parameters.
I had a (prebuilt) ported sub with a similarly high Q driver. The FR plot was "M" shaped. Still sounded OK if used <80Hz.
Bjorno's suggestion looks like a lot of bass / bang for the buck.So what would you guys recommend when using this woofer?
What other gear do you have? Other posts imply that you have a measuring mic & EQ, so you'd be able to tweak a complex build.
After such a long time, the suspension will stiffen up. Wobble it at it´s resonance frequency for at last 20 hours, with reasonable cone movement, I woud suggest +-5mm at last. Then let them cool down for about 2 hours (important!) and measure again. You will see much different TSP data, which represent the real, long therm values.
Most probably you can use them in quite different constructions/ simulations then.
- Subwoofers
- Oem brand 15" speaker, what to do with it...
