Odd Problem
I just got back from a road trip with my chip amp (stereo single chassis LM3875, BrianGT NI board, with passive volume control and input switching, not snubberized). It emits FM radio stations at low levels from the speakers. The odd thing is that it only comes from one channel at a time, and the noise alternates from channel to channel based on the input selected. It does not matter whether the input jacks are unused, connected or a source is playing. I swear it didn't do this before the trip.
For a little history, there has always been some noise through both channels with the pot (1M linear PEC law faked with 33k resistors) completely open or closed (outside of useable positions.) The noise was not audible as an FM station and the new noise is. It was previously pretty quiet in most of the pots range, though not silent. The input selector (grayhill, just switching +'s, common -'s) has always had some bleadthrough, I just assumed that was part of the design. None of these things was a problem for me.
The amp was very noisy at my friends house (on the trip), but I blamed that on dirty power. (Multiple audio systems, computers, an aquarium, appliances, etc) In retrospect I'm guessing that whatever happened occured on the way there.
It's possible that I've always had this problem, but highly unlikely. I've recently started using much more effient speakers and the ambiant noise in the house is low this time of year. I'm still awfully sure the problem didn't exist before. I'm also sure I have the selector wired correctly, so I can't explain how the noise would switch from L-R based on the input.
Any thoughts?
Paul
Are you SURE it's FM, not AM?
I can't imagine how FM could possbily get in, except from an FM tuner.
AM can leak into an amp with high gain and long, floating input leads.
Actually, the easiest AM radio to build is an LM386 with the gain pins shorted (200x gain) and a ~16" length of copper wire hanging off the input. The only problem with THAT radio is it only gets the strong station in the area.
Wes
Hmmm let me see if I can help.
A 1M pot is going to inject a lot of resistor noise, and help make the amp prone to RF noise. I would use either a 10K log pot or a 50K law faked pot.
You coulld add a 330pf cap to signal ground right after a 1K resistor in series with your input. This will shunt RF frequenties to GND by injecting a low pass filter on your input.
Russ
It is most definately FM. I can hear the station faintly, either 99. something or 100. something. Russ, I don't mean to doubt you, but I'm awfully sure that this problem began suddenly. When I was first testing the amp I spent some time with my ear right in front of the speakers and I couldn't hear anything like this. Then after it's little road trip this happened out of the blue. If it were the fault of the pot value, would it not have been there all along?
thanks for your help,
Paul
You might be surprised how quickly a pot which seemed fine can go south.
Honestly a 1M pot is very large for the application. Even if it were an excellent pot you would get quite a lot of resistor noise. Also, by using sucha large pot you decrease the current going to the input stage, which makes picking up stray signals by the opamp much easier. I speak from experience, as I have had issues very similar to yours. They can seem to spring up suddenly, but I can tell you that your configuration (if I understand things correctly) was never optimal.
Cheers!
Russ
Russ pointed you in the right direction.
By coincidence, you have been on places where radio signals are strong.
Again by coincidence, maybe some radio station on your area ingreased the power.
What you can be sure is that you should not use a 1M pot, long (and probably unshielded) signal wires and (maybe?) incorrect grounding arrangements.
Sort of O/T -- sorry -- but can anyone explain how an amp could pick up and demodulate FM into a recognizable signal?
AM is easy, current induced in wire, chopped by diodes or transistors, mega gain, boom, speaker reproduces it. But FM demodulation is a little more complicated!
Is it possible that maybe the noise is coming from a leaky radio nearby?
Wes
I'm using 1M shieled (Belden 89259) IC's, shielded RCA connectors, and only about 4 inches of wire between the outside world and the pot. The noise can't be picked up in the IC's, because it happens on unused inputs too. The chassis is solid aluminum. The grounding is per BrianGT's recommendations, but I was planning on trying Carlos's scheme the next time I had it apart.
How is it possible that with the pot in the same location, the noise is always from one channel only, and that channel changes based on the input switch? Surely were it the pot the noise would either be from one or both channels at any given pot setting. You guys know far more than I; I just want to be sure I understand the problem.
I am willing to replace the pot, I just think it is cool. I appreciate all of your advice, I was just hoping the answer would involve keeping my pot. If there is a chance just switching grouding schemes would fix it, I'm all ears.
Paul
I assume this still describes the prefered grounding arrangment:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=57526&highlight=
Unless you are getting humm or some other indication of ground loop(nothing you have described so far would indicate that) changing your grounding scheme alone will not make any change at all.
You cannot look at the pot in isolation. Notice my second tip. Some places just have a lot of RF and EMI, the low pass filter I described will shunt that to GND.
Give it a try. Its easy to do/undo.
Russ
The unused inputs will serve as antennas unless you terminate each input with a resistor to ground, on each RCA plug.
The length of wire is as much important AFTER the pot. Specially with a 1M pot.
It is not cool.:D
Besides the problems pointed out by using high impedance pots, the lower impedance ones (10~20k) also SOUND much better.
Sometimes it's not a question of picking the 'best' (or fanciest) parts, it is just a question of using the ones with the right values for the right place.
Well this is embarrasing. I moved everything around (moved the amp, jiggled the IC's etc) and the problem disappeared. I'll be curious to see if it returns. There is still some very faint noise, but it is on par with some high dollar tube preamps I've heard.
This was all very good knowledge though. I'll get a small value log pot to try. I'll also change the grounding. Believe it or not I even need to order parts to make the RFI filter. I'm going to make some shorting plugs too. Does the resistor value matter much? I searched a bit but couldn't find much.
On a related note, my cell phone gives the amp fits. Does anybody else have this problem? I have other electronic equipment (a metronome specifically) that emits the exact same loud buzz when ever the phone even rings. Would the RF filter Russ suggested help?
I appreciate all of your help. It seems like the amp is right on the edge of these problems so I'd rather eliminate them while I have the chance. I know similar questions have been asked before, but I thought this problem seemed unique.
thanks,
Paul
Yes, the fact that you can detect your cell phone should be your first hint. :)
It is very easy to add the LPF right after the pot. Remeber the pot/wire is like an antena itself, so put any sort of filter as close to the amp PCB as you can. A lot of well designed amps have such a filter on the PCB itself, though populating it is of-course... optional.
Re: shorting plugs
pjanda1 said:
Better searching revealed the use of everything from dead shorts to 10K resistors for shorting plugs. I was thinking of something in the 75-500 ohm range. That's just a guess though.
Paul
For a 10~20k pot use something around 47K soldered directly across each RCA plug. I mean inside the amp, no need to make external plugs.
Remember, the input impedance of the amp will be the impedance of the pot paralleled with the impedance of those resistors.
You don't want to go much lower than 10k.
Btw the interference of your mobile phone means that as it is, your amp is a good antenna. :D
Follow our advices, the problem will disappear.
So, here's a question -- my upcoming gainclone (BrianGT 3886) won't have a volume pot at all. I've been planning to replace the pot with a short-circuit and a 22K resistor.
Is that a reasonable plan? I take it fancy-pants resistors don't matter here since they're not in the signal path?
Wes
Hmm, I suppose I could have expressed that more clearly. :)
Short circuit is the red line.
How critical is the value of Rin, anyhow? I suspect not very, but obviously have not tested (still waiting for boards.. should come in today or early next week, yay!).
Wes
Wes, you can just remove the pot totaly...
When you have a pot turned to zero, input = shorted to ground...
at max you have it shorted to the signal.....with the input impendance of the resitor from input to ground... commonly soldered to back of rca socket...
I think you need to download the datasheet for the chip useing google... and have a good read...then come back with any questions.
Isn't the search function of this forum great? There are a couple of other audio forums I frequent. One of them has tons of good info buried in the archives, but it is actually buried. The search engine is so poor that one needs to ask the same question for the nth time to get a good answer. I'm glad my old thread could help.
pj
