Due to some problems obtaining certain transistors and then realising that they were now obsolete made me think that maybe some of the other trannies im ordering have been replaced.
Have the 2SD669 and 2SD649 been replaced by a more recent component??
Cheers Matt
Cheers Matt
5th element said:Have the 2SD669 and 2SD649 been replaced by a more recent component??
I got the impression they were obsolete when chasing for
them a while back, one reason being that they were discontinued
at some suppliers. However, Hitachi listed the status for these
devices as "mass production" in December and I found another
supplier to buy them from. Actually, when I check the devices
I bought I find that only one of these types are Hitachi, so
there seems to be several companies still manufacturing them.
BTW, the Hitachi datasheets have a very recent date (year
2000, I think) and no note about this being a revision, so
perhaps someone else used to manufacture these transistors
but quit production and Hitachi took over?
Matt
The 2SD649 is a made by Matsushita and Thoshiba
The 2SD669 by Hitachi.
They could be replaced by:
2SD649: BU2508A, 2SC3025..26, 2SC3685, 2SD821
2SD669: 2SC3117
Depending on the application of course
/Hugo 🙂
2SD669: 2SC3117
/Hugo 🙂
Netlist said:Matt
2SD669: 2SC3117
Hitachi manufactures both types. I don't think Toshiba does,
however. I don't think Toshiba manufactures either of them,
though, although they might have done so earlier.
The 649s I got seems to be manufactured by CDIL. I have
never heard of that company before, though.
Hi Christer
It's a strange world
I found the manufacturers in my data books, but were talking
'86-'87 here so I might be out of date. Although I have some recent data who
lists Toshiba for the 649’s.
I found the 649's also at: http://www.semicon.panasonic.co.jp/md/e-29269D.html
Found that CDIL. Our Indian friends are producing a lot of semicons these days:
http://www.cdil.com/
Digging is fun when we get some reply. So lets wait...
Confusion about parts numbers?
Now the confusion level is rising steadily. 🙂
I assumed Matt was asking about 2SB649 and 2SD669 which
are complementary and often used together. Neither or these
appear in the Panasonic list, but on the other hand both 2SB669
and 2SD649 do. I knew these parts existed too, but I
know nothing about them, and I don't think they are
complementary. However, I now see that Matt actually asked
about 2SD649 and 2SD669, so the confusion is total. Is that
what he meant to ask, or did he mean 2SB649 and 2SD669, or
Matt, I think you'd better tell us if you meant what you wrote,
or otherwise which transistors you asked about.
Thanks. I was to lazy to check it up myself right now. Actually,
I ordered a bunch of 2SB649 and 2SD669 in December, but I
haven't had time to use them yet. Hence, I hadn't really paid
attention to the brand before. Now when Matt asked, I thought
I should check that the ones I got actually were Hitachi, but
found that the 2SB649's were actually CDIL. Strangely, CDIL
does not appear to manufacture these devices according to
the online product list, but this list seems to be old, so I suppose
they have taken up production recently. To be more precice,
the transistors I have are labelled as P3B649A, which doesn't
look like a CDIL part number at all, but they do have CDIL
printed on them. I am almost getting a little bit worried now,
but why would anyone make pirate copies of such cheap
devices?
Netlist said:It's a strange world
Digging is fun when we get some reply. So lets wait...![]()
devices?
Thanks jackinnij. Though I didn't suspect those of my transistors
that are labelled hitachi, I doesn't hurt to compare, and they
look close enough to yours. The ones that are branded CDIL
are slightly more worrying, but at least CDIL itself seems to
be an OK company. It seems they've been around since 1964.
I used sometime ago TIP33/34CF from CDIL and they worked fine. Sometimes I made short circuit tests to verify the thermal sensors and the SOA protection of the circuit and these transistors passed very well on the test.
It was just one time, but, based on it, I think you don't have to be affraid of using CDIL devices.
blmn said:I used sometime ago TIP33/34CF from CDIL and they worked fine. Sometimes I made short circuit tests to verify the thermal sensors and the SOA protection of the circuit and these transistors passed very well on the test.
No, I am sorry if I was unclear. Although I had never heard of
CDIL before, they seem to be respectable and these transistors
are probably quite old now and should be easy to produce.
What bothered me was that they are not listed among CDIL
products on the CDIL website and that the part numbers
did not look similar to other CDIL part numbers. However,
the product list seemed not updated for a couple of years,
so i guess they have started manufacturing these devices since
the list was updated.
Christer,
OK. I just read your last post:
"The ones that are branded CDIL
be an OK company. It seems they've been around since 1964."
Not the others.
Not the others.
BTW, Christer
Are you in Sweden now?
'cause here in Brazil is 22:00h summer time. I suppose you really enjoy the night !!
And, I don't know if it's necessary a new thread, but someone knows the Rth(j-c) for these to3p isolated devices? CDIL catalog don't have very much info about the devices and I didn't find datasheets for them.
Hi all
It was me who mixed things up. I accidentally searched for the 2SB instead of the 2SD
Sorry for that
/Hugo - Is wrong now and then 😉
Sorry for that
Netlist said:Hi all
It was me who mixed things up. I accidentally searched for the 2SB instead of the 2SD![]()
Sorry for that
Well, i suspect the original question was mistaken too, since
it asked about two SD devices. While this may have been the
intention, I would rather think Matt meant to ask about
2SB649 and 2SD669, since these are complementary and
often used in amplifiers.
blmn said:BTW, Christer
Well, it was just after 1 o'clock at night here. But I guess you
are right that I like the night. I have a tendency to stay up late
just because it quiet and easier to think at night. 🙂
Now, since there has been some confusion, do you mean
2SB649 and 2SD669?
In that case, did you actually find any info from CDIL about
these at all?? I couldn't find them in their product lists.
Anyway, the cases are not TO3P, but TO126 (Hitachi actually
says TO126 MOD in the datasheets). Hitachi has derating
diagrams, so it is possible to calculate the thermal resistance.
They can disspate 20W up to 25 deg C case temp and are
derated lineraly up to 150 deg, so that gives approx. 6 K/W
(or 6 deg C/W if you prefer that 🙂 ). I have no idea if one
can trust this to hold also for the CDIL versions.
Sorry, my fault.
Actually I was talking about the TO3P Isolated CDIL devices that I used in my project (TIP33/34CF).
CDIL has no datasheets for their devices. I estimated something like 1 or 1.5C/w.
Coming back to the obsolete replacements, I have some 2SB546/2SD401 and they seem to be good drivers, but I didn´t find datasheets for them too (pecor and nec).
blmn said:Sorry, my fault.
If it is of any help, I checked the ST Micro datasheets for
TIP33/34. Tha package is stated as TO-218 and the thermal
resistance j-c is 1.56 K/W. I think TO3P is an inofficial package
name, so perhaps it is the same as To-218, but I don't
really know.
Yes, the similar oficial package is TO218, but these devices are fully isolated and I think the thermal resistance might be higher than TO218 non isolated.
I built the CF OPS (Complementary Feedback Output Stage) Amplifier (figure 11-4, p337) from Randy Slone’s "High-Power Audio Amplifier Construction Manual". I couldn't find 2SB649 and 2SD669 and used the NTE373 and NTE374 instead. They are listed by NTE as substitutes. I am having some problems with this amp. See:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=13469
- Obsolete trannies
