OB with beyma 18G50 ?
Looks quite good. With a passive filter (simulation says 5,6mH and around 100uF) and a decent sized OB you´ll end up with -3dB at around 40Hz and 92dB/2,8V/1m in the freefield, with a little bit of room gain even more. 2 18" will rock your house. I would do a trapezoidal OB - small for the mid, but wider for the bass drivers. The photos show an 2x12" + 8" FAST OB, which works very good.
All the best
Mattes
