ok.. to be really cheap i decided to try an OB design.
the drivers are the Alpha15a and the SEAS MG10SD09 (while i still can get it)
should i do 2 Alpha15a OB with 4 of the SEAS or 1 Alpha15a and 2 of the SEAS?
all run OB?
or scrap the SEAS and use a visaton B200 or a Audax PR170M0?
thanks!!
all run OB?
thanks!!
Per channel with a decent high eff tweeter.AudioGeek said:should i do 2 Alpha15a OB with a Audax PR170M0
alpha 15A
try music connection in adelaide, 08 8331 8960, at AUD$149 each. If you buy 2 free posatge.
or try this ebay site in the states,
http://cgi.ebay.com/Eminence-Alpha-...hZ004QQcategoryZ23794QQtcZphotoQQcmdZViewItem
they do sent to Aust land, after adding postage it is still cheaper.
gainphile said:I've only heard good things abount Alpha15. Anyone know where to get this in Australia ?
If the 10" OB I currently run using speakers found on the side of the road is sooo good I don't know what to expect of these eminence![]()
