Re: Re: OB efficiency with 2 or 4 woofers
Nope.
When using the 4 woofers there is no change between
series-parallel and parallel in power efficiency.
Only in voltage sensitivity there is.
The poor guy has to drive 2 Ohms when paralleled ...
Cheers
Magnetar said:
I would wire them in parallel, there will be a significant gain in sensitivity
The excursion will go way down
The distortion will go way down
They may become more directional depending where you place them and how you use
Nope.
Cheers
Re: Re: Re: OB efficiency with 2 or 4 woofers
LOL - What? I said sensitivity
If he uses them below 100 cycles like he says the average impedance will be much higher. Any good bass amp should have no problem
LineArray said:
Nope.
Cheers
Re: Re: Re: Re: OB efficiency with 2 or 4 woofers
You are right, so paralleled is even more attractive ...
Cheers
Cheers
I believe Hypex will have problems with 2ohm, but the big RECKHORM should do 2ohm all right, at least they claim 400watt with that load
But a good DIY amp will do 2ohm, I will soon have all parts fore the LYNX amp
My DIY 50watt will also do 2ohm and even not getting hot
I plan to do TWO subs of each 4 x 15", placed prelimenary at the sides of my room
In a couple of years I will have a dedicated room under the roof, and then all 8 woofers will be placed between the main speakers
Mains will be a pair of OBs with all DIY 6" and ribbons, time will show if a 15" midwoofer will be needed or if the 6" will do ... I have no clew about sensitivity, but anything above 90db will be fine ... I have most parts, the project started more than 5 years ago
Further I plan to build a 2way with the 98db AE td15m and CD/waveguide ... I simply have to own such a thing 🙂
tinitus said:I believe Hypex will have problems with 2ohm
As magnetar already said, the average impedance in
the resonance region will be much higher than the
nominal impedance. So parallel wiring should not be
a problem below 100 Hz.
You can choose, which voltage sensitivity you want ..
series-parallel or parallel .
Cheers
tinitus said:I believe Hypex will have problems with 2ohm, but the big RECKHORM should do 2ohm all right, at least they claim 400watt with that load
If you plot the impedance with the four in parallel below 100 cycles I think you'll find it's not too much of a bad thing.
Ok, thanks, I didnt think of that, I would prefer all drivers in paralel ... allthough I have always learned that its the DC-resistance that matters
An old friend want to buy my present speakers, so it may take a while before can order drivers, at this moment AE is looking into shipping cost ... I will also have to pay custom and taxes, good thing those drivers are cheap
Thanks my friends, I am a bit wiser now 🙂
Seems AE just got competition from DIY Cable with the Exodus DPL-15 ... 125USD
Actually I am now considering the new 18" MAELSTROM-X ... I have two very nice closed matrix boxes fore those 😕 -3db/30hz and -8db/20hz at 88db ... tempting
Just got a mail from David Haskins at DIY Cable regarding the mentioned new 18" Maelstrom-X ... btw I think a mms above 400gram is over the top ... IB15 reach the same Fs with half the mms
Shipping would be 200USD each
further will come tax and customs
all the same as I still want the OB with multiple IB15 ... still waiting fore an answer from John at AE regarding shipping ... he has answered previous mail ... it seems a bit of patience is needed
Well, I am in no hurry until I have the money fore my present speakers
- OB efficiency with 2 or 4 woofers
