Hi Guys and Girls
The nxV500 amplifier is now released and available for purchase.
The nxV500 module comes fully assembled and tested and comes with a detailed installation manual.
The cost for one module is $379.00AUD, €225.00Euro, $330.00USD, £175.00 Pounds. P/H for one or two modules worldwide is $20.00AUD.
For more details please email aussieamplifiers@bigpond.com
or visit the web site.
310 Watts RMS continuous sine wave into 8 Ω
550 Watts RMS continuous sine wave into 4 Ω
860 Watts RMS continuous sine wave into 2 Ω
Frequency Response 5hz to 300khz
Power Bandwidth 5hz to 100khz
Dampening Factor 800 @ 8Ω
RCA Single ended Input impedance 20kΩ
XLR Balanced Input Impedance 40kΩ
Closed Loop Gain 31dB
Signal to Noise Ratio -120dB
THD+N - TBA
Power Supply Rejection Ratio 105dB
Recommended Linear Voltage Supply +-80 volts DC
Recommended SMPS Voltage Supply +-75 volts DC
Operational Supply Voltage Range +-10v dc to +-95 volts dc
PSU Power Transformer secondary windings 55vac to 60vac (800VA Core)
Printed Circuit Board Dimensions 220mm x 50mm
Recommended Conrad heat sink MF30-100
THD+N - TBA
Here is some updated dampening factor specs for the nxv500 module...
Dampening Factor At 100hz 8 ohms =1300 - Output Impedance = 5 milliohms
Dampening Factor At 1khz 8 ohms = 915 - Output Impedance = 8 milliohms
Dampening Factor At 10khz 8 ohms = 248 - Output Impedance = 32 milliohms
Hi Everyone
The first listening impressions and photos of the HPA-nxV500 module now posted on the web site gallery.
http://www.aussieamplifiers.com/torbenamp.htm
peak power and what it'll be powering....
Thanks for all the information you have already given me on this module.
What is the 500's peak power?
I have two cabs, both 4ohms and one rated at 1000watts, the other 500watts.
2x12" drivers in each (Eminence Delta 12LFA and Eminence Deltalite 2512 II).
Will this amp really power both or just one of them?
