NVX
This amp protect Led is on but it is not in protect. I see oscillation on all channels but it has no output.I think it is in mute.I see 12v on the mute pin.Also R15e was open.
Any suggestions
The relay only engage for a slight second for the 4 channels but that is when i remove the remote wire to turn the amp off.
I get good audio on the 4 channels before the relay.
I see ocsillation on the sub channel but i did not get audio before the relay.
