What kind of Power adapter do I need in Volts, AMPs, ect...
Thanks...
Also what types of converter cables can I use for inputs.
Any help would be greatly appreciative...
Thanks...
Are these like the other Spectra Panels that require 12V at 2 amps...
Anyways, what is the polarity of the plug???
Please I need this to complete my project
I researched as much as possible, and just guessed, and I got it right.
In order to power a nview spectra plus, you need a 12 volt 1.5 amp power supply with + to the center polarity. These can be found at Radio Shack for $22.99
Not cheap, you could find it online cheaper, however I wanted the correct Adaptaplug to fit my unit.
Just trying to be helpful.
