nview spectra c will it play pal
Wazzup,
I am about to purchase a nview spectra c panel but I know it comes from america (although sold in AUS) so I want to know if it will play pal aswell as ntsc. If not is there a simple way to correct this problem, either way any help what so ever would be greatly appreciated.
Cheers and have a merry christmas
HELP ME PLEASE ANYONE
also I left this out, the panel has only vga input and im thinking seeings there is no s-video/rca input that even with a converter It might not support either format but this is highly doubtfull. Either way I am confused and in bad need of guidance anyone with info please help before I buy the wrong panel or lose it (because sellers hate waiting)
Mario007 is soo right!
if your panel spectra C only has vga in (it is marked as analog)
you don't have to worry about ntsc pal or any other format...
standard vga needs to be send!
if you want to go for cable, vcr, dvd or other video appliances, you have to check the converter you want to use.... a vha theatre, the cheese box or another converter and see if they take pal in, as far as i can remember the vga theater does, but i think i lost the manual, anyway you will find it on their website.
Jean-Pierre
versedws
dit you get your panel yet? I'm about to buy the same thing and was figuring the same question(PAL is also standard here). Now, i had did some technical researsh about this OHP and it seems there are 3 inputs for this panel (VGA, S-vidio and composite, if i'm right, if it's not: please let me know).
Now my question: Does it accept PAL , and wich are the posible output(s) they can be used.
tnx&greetz,
dirkje
