Nview Spectra C Question
I have did some searching in th forums and cant seem to locate any info on the power for this panel (I had thought I know it was 2V and I posted that a few months ago) but I cant seem to remeber where I got that info, or if it is correct. When I bought the panel of E-Bay it came with a 1V power supply. When the Panel was turned on there was a picture but it was all "squiggly" somehwere I found out that it could be a pwer problem ( possibly here somewhere). Well i had a 1.2V powersupply from a old Scanner tht I plugged in and the panel seemed to work fine. Now I have my Viewsonic tunner box, after figuring out it had to be turned down to 640X480 ( I know, easy to figure out, but hard to do when you cant get a picture and you have no manual) I got a picture on my panel, problem is its about 2 inches to the right and 2 inchs up from where it would be centered ( Im losing 2 inchs on top and 2 inchs on the right side of screen). This doesnt happen when I use the S-Vid or Composite connector. I hooked the tunner box up to a monitor to make sure it worked (and it works great, so its not the problem).
Im making a guess that my power isnt correct and with the higher res signal being input im having problems. So my question is, does anybody know the correct voltages and amps for this panel? (I know alot of you have them) what does the power supply say? Also does anybody have a manual? Im wondering if there is a way to move the image around? Im so close to being "happy" with this setup... the Tuner box has improved picture, and gave me a VOLUME control and a remote to adjust picture ( man this makes this set up so much nicer). Now I just need it to work. The picture was Good with Composite input, but with the tuner line doubling it looks much better ( maybe I have been hoping it would help, so im just imagining it, but to me it looks better).
Ok enough rambling, power supply specs, and a manual ..anyone, anyone... buller?
Clok
/EDIT/ once again i screwed up on my search, I have foudn teh power supply info on this board, but still interested in a manual/EDIT
