Hi Everyone, Now that I built an F5 I know everything, right? I have decided to build a Korg Nutube B1. I have the board and nutube, and I am finding the rest of the parts. I am going to build my own chassis. I want to make one or two modifications to the design.
1) I would like to make it less likely to mess up my speakers if somebody turns it on or off with the amp on. Am I correct in believing I would be able to use the soft start board offered on the diyaudio store for that purpose?
2) I want to build it with 3 input channels instead of the 2 that are in the design and build guide. I believe I would have to use a potentiometer with 3 0r 4 channels instead of 2 if I do that change. I am in the planning and part collecting phase of the build. Any help with planning this modification or with reasons for or against it will be helpful to me.
The volume pot is 2 channel -- left and right. And that is all you will need. You will need one left and right input from your 3-way source selector switch to the pot, and one L & R output from pot to the circuit board. Here's such a switch: Stereo selector switch
I happened to have this schematic, which is one mono channel of your three input stereo circuit.
Double it for stereo. The amplifier represents a phono stage, or it could be just another wire instead.
