There are several reasons IMO:
1.) Nothing ever works as good in practice as it should work in theory. If it really would, then the Sharp D-S amps would have a much better SNR than their 100dB (Theoretically 270 dB @ 20 kHz).
2.) The chosen dither is certainly not optimal.
3.) The chosen NTF may not be optimal either since I didn't spend too much time on detemining it. I just chose 200 kHz cutoff and fourth-order Butterworth for the NTF and then derived the coefficients for achieving it. This choice is quite critical: the lower the cutoff frequency - the worse the SNR, the higher it is (i.e. aggressive noise-shaping) - the more the loop is prone to instability.
Charles
Charles
