NS 670 yamaha speaker xo
I’m trying to rebuild the xo’s on these the electrolytic shunt caps are nippon chemi con cep series 50v (llong gone) nearest replacement in size/type/value is these https://www.mouser.com/datasheet/2/420/united_chemi-cn_04292020_SNX_Series-1842193.pdf but unfortunately they haven’t been manufactured yet! 17wks out is the estimate.
There is no real good replacement except for them except the m.d.l. series (jantzen) which are axial and going to be a pita to mount.
Need two 18uf and two 47uf N-P
Any ideas/help would be appreciated.
Thanks adason, I believe that’s the same m.d.l. I found at Madisound, the problem is they are mounted on a tight pcb and need to be radial. I could make axial work but would have to lengthen one of the leads and goop the crap out of it to hold it in place, my goal is to eventually sell these speakers (unless I like them too much....that potential is there) and would like to keep it as neat as possible. Those SNX series fit the Bill perfectly, but idk if I want to wait 4 months for something that may or may not show up!
Is Nippon usually good about keeping their timeline?
