For Sale NP First Watt F6 & F5turbo (transformer required)
Things you have for sale.
The clear out continues.....I have have a very nice Nelson Pass (First Watt) F6 amp built into a DiyAudio 5U deluxe case.
The only thing you would need to complete is a 500vA transformer with 2 x 0-18v secondaries.
I have powered it up on the bench PSU and its working as it should:- bias is set to 0.6xx mV per channel with the offset less than 10mV.
It is a large chassis and by default with a Class A amp runs hot 45c - 50c
The chassis came from HiFi2000 via DIYaudio shop as did all the components inc the PSU, so all the jfets and are mosfets are matched.
right channel as we look at it.
left channel as we look at it.
As a bonus it also comes with a full set of F5turbo boards (without mosfets but inc the diodes) which you you would need to source then you can swap the F6 boards for these if you so wished. It runs of the same PSU 25vDC.
There is a load of info of over at DIYaudio and you would need some DIY skills to complete.
£500 the lot.
Cash on collection (Hampshire UK) I can ship but because of the weight 'would cost quite a bit'.
