This outlet box has the bond wire to earth cut...unbelievable, I know! LolAre you sure the outlets ground pins are not connected to a common grounding wire? Or perhaps to the neutral line (only 2 wires network)? I find it hard to believe the ground pins in the outlets would be left unconnected.
The neutral would be connected... All of them in the building would be connected eventually at the junction box.
