Hi everyone,
I have built a sealed enclosure for full range 4 inch driver. i added 3db BSC filter in series with the driver and it sounds good. These are cheap full range drivers and sounds good at moderate volume levels. I want to add a parallel notch filter to these. Please advice me whether notch filter should be added before or after Baffle step compensation. Thank you.
