Hi.
I have a Cambridge CD2 that is a bit poorly,and I could do with a little help to sort it out.
The problem is,when I have the player is on for a while(a couple of hours),it starts to give a mildly distorted sound,a bit like the sibilance you get off a mistracking record deck.
Though this is not really nasty,it is very noticable.
I have read other threads which discuss problems relating to the chips,but before doing any work on them I need to know whether it may be something else.
The deck itself has a CDM4/11 transport,and has "issue 3" printed under the DAC section.
Another small fault is"ERROR 1" during switch on,on both displays,though I suspect this may be normal.
I have only a basic knowledge of electronics,so any help would be much appreciated.
Thank's for your time.
