For Sale NOS FETs HARRIS IRFP254 + Others
Things you have for sale.
For sale: NOS original Harris 9623 datecode IRFP254
These have good SOA and nice linear transfer characteristics.
Transistor, N CH Mosfet. Max voltage: 250V. Max current: 15Amp. Dissipation: 190 Watt. Package: TO-247AC. P/N: IRFP254. Note: RDS on: 0.14 Ohm
Approx 30 available.
Asking €3 each.
Shipping Worldwide at cost.
Not mosfets this time, BF337 NPN transistors. Quite usefull for VAS duty, or tube amplifier applications.
Aksing €0.50 each, or 10 for €4
Type Designator: BF337
Material of transistor: Si
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.8
Maximum collector-base voltage |Ucb|, V: 300
Maximum collector-emitter voltage |Uce|, V: 225
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 0.1
Maksimalna temperatura (Tj), °C: 200
Transition frequency (ft), MHz: 80
Collector capacitance (Cc), pF: 6
Forward current transfer ratio (hFE), min: 20
Noise Figure, dB: -
Package of BF337 transistor: TO39
BDX78 original Philips, not very special but nice vintage PNP transistors to use.
€0.25 each.
Type Designator: BDX78
Polarity: PNP
Maximum collector power dissipation (Pc), W: 60
Maximum collector-base voltage |Ucb|, V: 80
Maximum collector-emitter voltage |Uce|, V: 80
Maximum collector current |Ic max|, A: 8
Maksimalna temperatura (Tj), °C: 150
Transition frequency (ft), MHz: 7
Forward current transfer ratio (hFE), min: 30
Noise Figure, dB: -
Package of BDX78 transistor: TO220
LM385Z-2.5 Shunt voltage references.
  • ±20 mV (±0.8%) max. Initial Tolerance (A Grade)
  • Operating Current of 20 μA to 20 mA
  • 0.6Ω Dynamic Impedance (A Grade)
  • Low Temperature Coefficient
  • Low Voltage Reference—2.5V
Asking €4 for 10pc
