I just built the noisy cricket lm386 amp and have a problem. It does amplify and if it is just voice, it sounds fine bit music does not. Music sounds like it is out of phase (?) to not in sync.
Any suggestions would be appreciated as I am just learning how to build amps.
Thank you so much,
Ron from California.
Thank you so much,
The noisy cricket as just that Noisy , it isn"t meant for Voice or Music it is meant as a guitar amp so if the amp sounds Okay with a guitar plugged into it then it is working correctly...
It does sound fine with the guitar. I though it would be a little more dimensional.
Thank you for the reply.
Well if you want a guitar amp that can also be used for playing music then building a guitar amp that has a separate guitar preamp and a power amp then you can put an insert between the pre and power amps for plugging in a music signal ...... I build most of my guitar amps this way but not for plugging in a music signal but as an FX loop so I can insert guitar FX gear between the pre and power amps .....
