Noisy A/B Amplifier
So an active speaker...
If the noise is controllable via the level control then it points to a front end problem, whereas if the noise is an all or nothing thing then could the power amp stages be being automatically powered down which some designs do when there is an absence of signal.
So I wouldn't like to begin to even guess without seeing circuit details tbh.
In order: (1) The noise increases or decreases in line with gain setting. (2) It is not hiss - more like static. (3) Shorting the input results in no change.
New symptom: the problem seems intermittent. The amp has been on for an hour with no input signal. The noise eventually reduced to virtually inaudible.
I am unable to find a schematic for this model (MK3). A schematic for a MK2 is attached.
I can only see a block diagram in that manual unfortunately.
As with anything, the first step is to check the supply voltages and make sure they are clean.
If the problem is worst when cold then you might have some luck with freezer spray to narrow things down (a cheap can of butane based air duster used inverted works well as a substitute)
It's all good. I've no intention of fixing this problem. I like to recycle. Occasionally I come across an item that may be as easy fix (for somebody else).
This unit stands me at around $10 ($150 retail). My only means of input is via a computer, the output signal is not that of a mixing desk. There is a chance the background noise may not concern somebody else.
If I pass the monitor onto another party I do not want the monitor to (a) fail in the first 45 minutes, or, (b) Burn their house down!
