Hello all,
I have a '78 twin reverb with no sound.
All tubes have been replaced.
Red light is on.
Connection to speakers seems intact.
Yet no sound at all, even a hum. My experience in fixing amps is limited at best but any help that could be given on how to troubleshoot this would be great.
Red light is on.
A number of things could cause absolutely no sound. A defective stand-by switch is one. The speaker itself and/or the connecting wire and plug. Check these as a system by pulling out the speaker plug from the amp and measuring with an ohmmeter. Or use a 1½ volt flashlight battery to check the speaker through the wire. It should make a scratching sound when connecting to the battery.
Are all the tubes lit up? Is there really no hum even with your ear right at the speaker and the volume up? Is there a second B+ fuse?
Is it one of these?
http://ampwares.com/schematics/65_twin_reverb_@20manual.pdf
or this?
http://ampwares.com/schematics/twin_rev_ii.pdf
What power tubes is it running?
A schematic would help.. 😀
Possible maybe?
http://ampwares.com/amplifiers/fender-silverface-twin-reverb/
Just be careful these amps can hold high voltage..so don't poke about unless you know what you are doing!
M. Gregg
or this?
Possible maybe?
M. Gregg
Is it one of these?
or this?
Possible maybe?
Fender Silverface Twin Reverb | Ampwares
M. Gregg
This is it
From the subheading at the top of Tubes / Valves:
Tubes / Valves All about our sweet vacuum tubes 🙂 Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum
And from Instruments And Amplifiers:
Instruments and Amps Everything that makes music, Especially including instrument amps.
With the guidance of an awesome school teacher, I started repairing and building tube amps when I was about 12. The first thing he told me was when you are testing the voltages on a tube amp, keep one hand in your pocket. It just may keep you alive. Good advice.
Just a guess,
Either HT (B+) open, OP Tx open or bad connection. Speaker lead or voice coil open..possible stand by switch fault or broken connection. The mains is OK because the heaters are working!
Do you have a multi meter?
If you don't know what you are doing then be guided by the guys here! Don't play with a live chassis it can kill you easily.
There are some tests you can do with it switched OFF!
High voltage..Take care..
M. Gregg
M. Gregg
Several things could be wrong with the amp.
First you need to be competent and comfortable with working around high voltage. According to the schematic, your B+ is 410V. It will be more likely 415-425V as line voltage is higher today than when the amp was designed.
Given that you can follow the appropriate safety procedures, you need to remove the chassis from the cabinet, and support it upside down on your bench.
I would check the continuity in the output of the output transformer first. If that looks good I'd go on to the voltage checks.
Since the tube heaters are on, the fuse and ac switch can be ruled out.
(By the way, you need to change the power cord to a three prong safety cord while you have the amp out of the cab.)
Your problem is most most likely in the HV section. You need to measure the voltage at the standby switch with it off and then on, and at the input and output of TR2. If TR2 is open (not likely) you will lose all high voltage to the preamp driver and screen voltage to the output tubes. No sound will ensue.
If you have appropriate voltages on both sides of TR2 (schematic values up to 1.05X schematic values) then the problem lies elsewhere than the B+.
Also check the B+ on the output tube plates (open OPT).
I doubt the bias voltage is sufficient to shut the tubes off completely, but it is also a possibility. Check the voltage at the two ends of the 10K balance pot. This is the same circuit as the Bassman 50 I just finished working on.
Bias voltage could be as high as -45V. I had to increase it in my case to -45V to get the zero signal tube current where it should be.
If it is greater than -45V I would look at a possible bad connection to the 15K or an open 15K resistor.
In post #2, Hollow asked the OP to check the speaker, but the OP merely restated the tubes were lit.
The speaker wiring may LOOK intact, but that tells us nothing about its integrity or whether the speaker itself works. Before ALL that other stuff, verify that the speaker and its wiring will function.
Your problem is zero sound, not poor sound or weak sound. So your trouble is not from some wrong voltage. EVen grossly wrong voltages will result in some sort of sound. COnsidering the general lack of internal fuses in Fenders, a loss of B+ is possible, but not at all common.
Unplug the speaker wire from the amp, get your ohm meter, and measure resistance from plug tip to plug sleeve. Open? Or some low resistance?
- Live Sound
- Instruments and Amps
- No sound....
