No sound on one channel
If power is on, you may compare VOLTAGES, starting with power supply (if separate).
Search for a ground point (easier if common to both channels) and select some other points to compare, with no input signal. Check fuses also.
It can be a faulty power supply, or even burnt output transistors.
Good luck!
Max.
