No power on start up
Hello, first timer here. I have a Heathkit AP 1800 preamp that worked perfectly before moving recently. It was cushioned, boxed and carefully hand delivered via my truck's seat to my new in the Seattle area...less than 30 mile drive. Now, after install at the new home, the PA will not power on. Anyone in my area with suggestions on whom or where I can take it for repair?
I would attempt to diagnose and repair, but I don't have the tools or expertise. Thank you in advance for any of your helpful reply(s).
First, make sure the wall AC outlet works by plugging in something else. Then work the preamp
power switch back and forth with a little pressure. If you have electrical contact cleaner, use some.
Then see if any tubes or the power light come on. If not, unplug the cord from the wall, wait
ten minutes for the power supply to discharge, and look for a bad fuse, or a loose connection,
either near the power switch, on the rear AC outlets, or at the inside end of the power cord.
Free download Heathkit AP 1800 Schematic
