15000uF/63V
Hi umut1001,
First bank of 15000uF/63 capacitors ready to test - next week!😀😀
Dual -mono amp:
2 X Icepower 250A,2 X 350W trafo,4 X R3060G Stealth diodes, 2 X 90 000uF Nippon chemicon KMH capacitors, low noise 2X12V regulated soply with Rubycon ZL 2000uF/25V + BlackGate F.
Will inform you!😉
Best regards
Joze
Hi umut1001,
Dual -mono amp:
Will inform you!😉
Best regards
Joze
Hi Jazzy.Would you send your Kendeil 50v 68000uf and Nippon chemi-con 63v 15000uf test results with us?Thank you!
are these sstill available ???i will go for 20 15.000 mfd 63 volt can i pay with western union ???
Hi.They are still available.I did not use western union before.But i will try and you will be reason for this 🙂
- Vendor's Bazaar
- nippon chemicon kmh 63v 15000uf
