• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Nigel Wright's Vendor Thread
Murton-Pike Systems Vendor Thread
:cop: Single thread combined from others in Vendor's Bazaar.
PCBCAD51 available at Murton-Pike Systems
Touch screen compatible.
2018 Windows full version of PCBCAD51 PCB DESIGN SOFTWARE with 127 LAYER AUTOROUTER.
Runs on Windows XP (SP3) , Windows Vista and Windows 7, Windows 8 and Windows 10.
This is a mature product with no bug list, if I find a bug it is fixed immediately.
Support for this product is second to none, you are supported by the guy who wrote this software.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, circular and QUAD PCB footprints from your parameters.
Schematic entry with auto convert schematic to PCB ratsnest, unconnected pin scanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance and continuity check.
360 degree rotations of pcb components with obround pads.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
3D PCB viewer module.
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling, inversion and mirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (PCBCAD51 files only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127 copper layers.
127 resist layers.
Copper pours, each layer can be connected to a different NET.
2 silk layers (upper/lower)
Comes with symbol libraries, 4000, 7400, smd4000, smd7400 and general as standard.
User manual in each module
This is the full version and not a crippled, time limited or downsized version.
This is a fully integrated package and not a suite of amateur free programs cobbled together.
Fully supported package with email and phone help lines.
Note: This is the 2018 version and not an obsolete version.
PCB design software
127 layer PCB design software with:
Schematic capture.
PCB Entry with autorouter, clearance checker.
Schematic and PCB symbol generator wizard.
Schematic to ratsnest PCB converter.
Integrity checker.
PCB to Gerber/Excellon file generator.
Gerber/Excellon viewer.
3D PCB viewer.
Parts list generator
Output to printer or manufacture files.
UK £18
Rest of world £21.
cresswellavenue@talktalk.net for more info.
ok thanks, found it
Looks neat, a bit simple
But price ok
May work fine fore woofer amp
But I would like a bit more information
From experience, without knowing more, I wouldnt use much more than max 2x 50Vdc
Thats about half the promissed output, if its 8ohm
But maybe its 4ohm, doesnt say
I have old 2x33Vac trafos that would suit it, fore 150watt, 8ohm
tinitus said:
ok thanks, found it
But price ok
Your transformer would work fine with it.
The amplifier is rated at 450WRMS into 4 ohms.
