Hi all
I'm looking for a nice single or double fuse holder for an amp (European 230V 1.6A fuse), that provides for a good connection with the fuse. I wouldn't mind if it also looked nice and well-engineered (I do like eye-candy, also when it just sits inside the case).
Shurter make a plain-looking gold fuse holder, but I can't find them in small quantities and they're SMD type. PDF
The bay is full of gilden fuse holders for car-audio, could they be used for 230v? (IANAEngineer) To the Bay.
Any experience/ideas?
ElEsido
ElEsido
Avoid car audio fuse holders, they are usually rated for 48 volts DC max.
I usually use the combined IEC Socket and fuse holder for projects.
This is the type IEC connector, takes a 20mm fuse.
IEC inlet with fuse
IEC inlet with fuse
