nice find
When visiting a well known furniture store I stumbled across this:
It is porcelain with a nice wooden ring which is an airtight fit. (silicon)
When I saw the volume, 1.7L i immediately thought of the FAST i was planning to make.
My question is, would a tang band w4-1320 be a good driver. It fits perfectly and the recomended CB-volume is 1.8 L. the driver then goes to about 200 Hz.
My Questions:
Is the narrow baffle of 15 cm an advantage or not.
In the simulation there's a gradual rollof from 200 Hz downwards. Which type of highpass should I use? Should I worry about too much excursion?
I'm not shure which bass driver to use. Have got 2 Visaton w170s-8 laying around, so thinking of using them.
