NFB Clarification
Good evening all,
I wanted to get a clarification on how to tell if I have positive or negative feedback.
I have a 500k pot in my feedback loop. when I increase the resistance, the volume increases. That is positive feedback correct? If so, can I swap the two wires coming off the preamp tube going to the PI caps to correct this?
Also, thanks to everyone for helping me learn the do's and dont's of component placement. My hum issues are pretty well gone.
Special thanks to Azazello, if I wouldn't have added the choke to the power supply that he suggested, I would still have a nasty low level hum from the simple/dirty power supply.
Thanks again
Brian
Thanks so much Wavebourn, I just wanted to make sure I didnt phrase my question in a way that seemed like I was asking or implying the wrong thing.
BTW - Nice site you have.
Don't be sorry.
If amplification factor through the loop of positive feedback is a little bit greater than 1 on some frequency the amp starts oscillating. Think of it as if signal from output coming back to input is amplified, this amplified signal comes again to the input, is more amplified, and so on...
Just to state in clearer terms than "yes" or "no"
when you increase resistance you are reducing the feedback signal, so if the volume increase with reduced feedback signal, it must be negative feedback.
Obvious to knowledgeable folk live Wavebourn 😉, but I always have to think it through literally 😱
This assumes that the pot is in series with the loop, not paralleled to ground - this would have the opposite effect!
Changing volume via a feedback loop can lead to oscillation at low volume, because this is when the loop gain is at its highest. Is this just a pot during tuning, to be replaced by a fixed resistor once you are happy with the design?
