So I've ordered a few bits to start tinkering with DIY speakers and CamillaDSP (RPi5 & HiFiBerry DAC8x):
4 x Wavcor WF168WA02
2 x Vifa NE25VTS-04 tweeter)
3 x TPA3255 boards -- (https://www.aliexpress.com/item/1005006640455408.html)
I'm pretty unsure about proper tinkering "safety", basically how to avoid destroying things.
I'm not planning passive crossovers. I'm going to use an amp channel for every driver.
I gather I should use a 'protection cap' on the tweeters.
I'm going to run the TPA3255 boards from a 24v SMPS dialed back a few volts that should severely limit the watts going to the drivers. I was thinking one TPA3255 board for one L & R driver so one TPA3255 board to run the tweeters. I want each woofer to have it's own amp channel so that I can try a 2.5-way crossover.
So the question is what additional precautions should I use while testing?
Richard
Richard
You can get a electrolytic 20-40uF cap for a few $$, e.g. from Wagner or Speakerbug, or possibly Jaycar - cheap insurance.
Geoff
Geoff
