I'm a long time lurker.
I'm going to use two Wavcor WF168WA02 (+ Vifa NE25VTS-04 tweeter) with a DS270-PR (to keep the enclosure as small as possible) to build an active 2.5-way for fun, so I read Qts should be below 0.5, in "Explain it like I'm 5" terms, why and what happens if I break the 0.5 rule?
Wavcor Q:
7.10 - Mechanical Q (Qms)
0.56 - Electrical Q (Qes)
0.52 - Total Q (Qts)
I'm a hobbyist wanting to build a few speakers mainly to tinker with CamillaDSP and using a different amp channel for every driver. I'm not wanting to delve much into math, making perfect enclosures or passive crossovers. It's definitely not about perfection for me.
In the future I'll probably cannibalise old speakers and buy new drivers to experiment. I went with cheapish drivers because I figured I might mess things up.
I have a workshop, can work with wood and metal, know how to solder and have quite a few bits of electrical test equipment.
Cheers
Richard
Current main Roon system:
MiniDSP CH1 > Valvet A1r > Salk Songtower RT
MiniDSP CH2 > Valvet A1r > Salk Songtower RT
MiniDSP CH3 > SVS 3000 micro
MiniDSP CH4 > SVS 3000 micro
Wavcor Q:
Cheers
Richard
