I was wondering if a Proxima Ovation+ 846 would work well with my DIY LCD projector project
Here's some specs:
Computer Compatibility: IBM PC, PS/2, Pentium, and compatibles
Apple Macintosh, Power Macintosh and
PowerBook families
VESA
NEC 9801
Video Compatibility: NTSC M 3.58 MHz
PAL B, G, H, I, N, 4.43 MHz
SECAM 4.43 MHz
S-Video
H-Sync Range: 15 to 40 KHz
V-Sync Range: 50 to 75 Hz
LCD Panel: Active-matrix color TFT (Thin Film Transistor)
Resolution: 640 x 480 color pixels
Resolutions Supported: VGA (640 x 480) and SVGA (800 x 600) Fit-to-View®
Contrast Ratio: 100:1 (typical)
Number of Colors: 16.7 million (24-bit color processing)
Display Area: 10.4 in. (264 mm) diagonal 8.3 in. x 6.25 in. (211 mm x 158 mm)
Interface Connectors: Multi-standard computer video interface (DB25 connector)
PC and Macintosh output (DB15 and HD15)
Bi-directional serial and Apple Desktop Bus
(ADB) interface (mini DIN-8)
Internal edge connector for Cyclops 2050 connector
S-Video and composite video input for multi-standard video support (mini DIN-4, RCA)
Stereo audio input (RCA) and output (mini-jack)
Graphical User Interface: Pull-down menu system
LightBoard highlighting and annotating tools in 8 colors
User Interface Control Options: Cyclops 2050 interactive pointer system
100% Microsoft compatible serial mouse
Here's some specs:
PowerBook families
VESA
NEC 9801
SECAM 4.43 MHz
S-Video
the 846 is a decent panel. iv got a sharp qa -1800 and im happy with it. if youre gunna use a xbox or ps2 then a panel is the way to go as far as im concerned because its got rca inputs well not all have the inputs make sure to check. if yer just gunna do movies then yer gunna be more happy with buying a lcd monitor and stripping it higher res and bigger size.
Thanks, I was planning to use it for as many things as possible, and I do have an Xbox, so it should be perfect
being a newb sucks...
Does the nView ViewFrame SpectraPlus to the Proxima Ovation+ 846. I've scoured the internet, via google, for any specs or info but nothing came up
