am new to this hobby, and have read thru most of the posting,
but couldn't find a ref site or guideline in amp (BJT/MOSFET)electronic components selection, especially those directly affecting sonic?
ie what type of capacitor, resistor,… etc to use?
thanks
thanks
Hi, my general approach is to use the minimum to do the most. I am probably far removed from being a "golden ear".
As far as sonics are concerned, it depends on what you consider good sound. If you want sonic accuracy, as in low distortion, consider BJT's in the output. 2SA1302, 2SC3281 pairs are powerful with low distortion, and have the lowest beta droop -- which can be a significant source of distortion at low impedances. If choosing MOSFETs, the 2SK1058, 2SJ162 laterals are extremely rugged and low distortion (more than BJTs tho'), and are designed specifically for audio use.
It all depends on what distortion means to you -- some people like more of it, and choose MOSFET designs specifically for that reason. One benefiet of MOSFETs -- they are usually harder to destroy than BJT's =).
