Hi, I just started to gether part for my first DIY pj. Before I start making orders, I have a few questions.
1. I saw on the LL site that they have this UV filter, is this alone good enough to filter out most of the heat genearted by the light source?
(I plan to do a direct light source without any mirrors with a 400W MH right behind the lcd) And where should I place it? between the light source and the Fresnel?
2. Is the len kit from LL good enough ? do I need another Fresnel between the LCD and the lens triplet?
3. I plan on using the ushio S400DD, is this a good lamp for pj? what about those ED28 (much cheaper), how do they compare with the ushio S400DD? how much difference?
4. I am all confuse about the ballast. Sometimes I see ANSI ##, sometimes M##, which one should I look at when I look for matching ballast for the bulb that I decided on?
5. Will having just one fan blowing out too hot for the lcd (based on my plan in 1.?
Thanks in advance.
Thanks in advance.
