Hi there,
I'm planning to build a (frugal) Aleph-X and am wondering
about some details of the power supply.
I'm hoping to use two 300VA 2x12VAC transformers in a
single stereo unit. The secondaries of each transformer
will be tied in parallel and will generate one rail. The
two channels will share this single power supply.
Would this work, or should I build a separate PS for each
channel?
Also, my local surplus store has some 25VDC 220000 uF
Phillips caps. The price is right, but I'm a bit worried
about using caps with that high a capacitance value.
Aside from inrush current, which I hope to control with
thermistors, are there any problems I should worry about
if I want to use these large caps? Will the transformers
be able to handle them?
Sorry for these incoherent newbie questions.
Dennis
channel?
Dennis
Hallo Dennis,
there aren't problems with 220000uF capacitors.
But you need 2 rails of supply ; one positive and one negative.
If each transformer has 2 secondaries there aren't problems either.
A word of caution is for the VA rating that for my opinion is a bit closer to the needs.
stefanobilliani said:A word of caution is for the VA rating that for my opinion is a bit closer to the needs.
We are fearless amplifier builders. A little heat doesn't
scare us at all.
What a great line. I love it!
scare us at all.
Ok, first of all "frugal"
! Frugal sounds to me like sanyo boom box. Frugal and alephX don't belong in the same sentence!
What board are you going to use? The Grataku/Chad board it's particularyl well suited for dual mono. Even if we didn't intend to @ $5/each it came out to be dirt cheap. Since you have the luxury of having two transformers you might as well make use of it. I am going to do just that and use Nelson's trick of joining the grounds via the bridge. 300VA transformers are really OK for a 4.5-5 amp bias x channel. If you can buy 8 of those 220000 you could do a two chn. PS with C-R-C or a C-T-C with anywhere from .3 to 1 ohm R or T (under load). The PS voltage would be anywhere from 14 to 11 V with ripple between 15 and 2 mV. A thermistor in series to the primary should be good to safeguard the transformer primary. The rectifier may need a little more care. I would use two bridges one for the positive and one for the negative rail, 2 is better than 1.
Dennis Hui said:?
Phillips caps.
And which store would it be?😉
Re: Re: newbie Aleph-X PS questions.
And most importantly: Why is it Canada?
/UrSv
/UrSv
It was at Active Surplus. By the time I got back to
the store, they were all gone. 🙁 (They had a good 20
pieces.)
Oh well...back to square one.
Dennis
pieces.)
Dennis
- newbie Aleph-X PS questions.
