This from one who has Nathans?In not being just a poor man's Summa.
That's it?? Nothing else??
We are going way off topic. Maybe these last few should be moved to a new thread?
Rob🙂
It's spot on topic by one view, actually, Rob.
[Others read between the lines back on Page 1.... 😉 ]
Floyd and crew do not even consider image in their criteria for a loudspeaker. It is heavily weighted on spaciaousness. They don't even consider any dynamics, nothing in the amplitude aspects. There are a lot of holes in Floyds work, but its still the best there is on the subject if you can recognize where these holes are at.
Those were the first things I thought about. I also know how these wide dispersion speakers sound and they are pleasant. It's interesting to me that they supposedly sound more clear on vocals based on that research. This isn't what I'd expect. No matter, I have much to read yet.
One other matter, for speakers more like yours, do you have a recommended placement from the nearby walls?
Thanks,
Dan
Rob🙂
Yes, please. There is a name for what is happening here.
Thanks,
Dan
Speakers (and listeners) should be as far away from all walls as possible.
Yes, this is generall true, but generally impractical. Never put the speakers right at the wall and don;t move them too close together to get away from the walls either. The room will dictate this.
You're missing the point - where's the data? Just because I can build a speaker doesn't mean I should. Building something just because it's cheap is uhm cheap.
Sorry for the continued hijack, but like this? Augerpro also has some measurements of the completed speaker up over at avs and htguide somewhere.
How close would you say is too close? When the polar patterns overlap or is overlap beneficial. Or is overlap nonconsequential?
No, whole system, ±90° in 7.5° increments, like here. The crossover region is the fun part. Data "somewhere" is no data.
I haven't built and am not building an "econowave." Neither was augerpro. It was his design. You want data, it's there. You want more, this is diy audio.
Well, heat rises too much for my liking, so one question more on-topic: how do polar plots like the ones proposed by Earl correlate to perception of (phantom) sound sources, i.e. their timbral and spatial qualities?
DE250 and Kappalite clearly stretch "Econo," but they still come in ~1/10 the cost of the commercial product being promoted here.I haven't built and am not building an "econowave." Neither was augerpro. It was his design.
'Zactly....You want data, it's there. You want more, this is diy audio.
'Zactly....![]()
Pretty narrow minded view and off-topic. I obviously asked the wrong guys. Please accept my apologies.
No problem. It was "just pretend," apparently, is all:Pretty narrow minded view and off-topic. I obviously asked the wrong guys. Please accept my apologies.
I would be willing to build a EconoWave box and measure it along with the Nathans....
[You're off the hook.... 😉 ]
I enjoyed the white paper and it's certainly come in handy in discussions I've had on various forums since the 'average audiophile' needs to know why they should consider purchasing plain looking speakers without beryllium-plated uranium supertweeters with XPL-57 technology 😀 Also, Dr. Geddes...I know you like to cite your customer reviews and while I personally believe they are spot on..understand that EVERY speaker has those same reviews. A lot of ignorant listeners out there. Stick with making up a fancy name for your waveguide.
Because of the angles the speakers are toed-in, placing close to a side wall hasn't been an issue for me. I've also found that my 4.1 setup with a 'phantom' center works incredibly well and does a convincing job, at least between the speakers (listening position-wise). I've never been fond of center channels because I always feel like I can locate the speaker too easily. The added cost and size of the Abbeys was a factor, too, I admit.
What's your beef, bro? Hi-jacking the man's thread, being rude, and pushing a ripoff of his idea is...uh...pretty weak.
'Zactly....![]()
http://www.diyaudio.com/forums/multi-way/123426-horn-vs-waveguide.htmlWhat's your beef, bro? Hi-jacking the man's thread, being rude, and pushing a ripoff of his idea is...uh...pretty weak.
The "White Paper" is a gratuitous Geddes promotional piece in the guise of an educational submission posted here for discussion, the thesis being that Summa (and similar Geddes products, presumably,) are better than anything, and we should buy them.
My "beef" is, as others also observed, Earl appropriates the developments of others for this purpose without referencing or crediting them, implicitly putting forth their work as if it were original and uniquely his own.
It's marketing hype, pure and simple, and if it belongs here at all, the invitation to comment in the first post clearly grants license for presentation of alternative views, my own being that many of the elements of directivity highlighted as advantageous therein are readily available to readers via more economical means than the core premise would have everyone suppose....
The constant-directivity 2-way is a Geddes innovation?... a ripoff of his idea....
[EARL -- send this man $100 for posting that....
- More Vendors...
- GedLee
- New White Paper posting
