Hi Guys,
So let me first just say I'm new to electronics and so the answers to some of these questions might seem pretty obvious to some of you. But googling has only gotten me so far on some of these question so here I am. I've been trying to figure out what's wrong with my 7250PE receiver that I picked up at a thrift store for $30. Long story short, a couple people suggested the reason the speaker outputs and headphone out might not work (where as the inputs and tape out does work) is because one or more of the output transistors might have shorted.
I've started testing them with my multimeter and haven't been getting the readings I've expected to.
So I wanted to ask, can I test output transistors while they're still attached to the board and heatsink or does that give me bad readings?
Also, with the diode test of my multimeter, I measured the four 2SD1715 NPN transistors I was told to check first and I only get an open circuit when I connect the positive terminal to the collector and the negative to the base, and when I connect the positive to the collector and the negative to the emitter. All other times I get readings ranging from .559 to 1.223. From doing some light googling, I learned that I should be getting an open circuit reading most of the time. What do you think I'm doing wrong, or what do you think that means?
Thanks!
Thanks!
Hi, If you are using a multimeter to test transistors you will need to remove them from the circuit first, other things connected to the transistor (eg capacitors or resistors) can throw out your measurements.
You can get in-circuit transistor testers, but they work because they are a bit more complex than a simple diode test that a multimeter can perform 🙂
Tony.
Tony.
Tony.
If they are shorted, you can tell with certainty they are bad while in circuit. To tell if they are good, then they need to be removed but unless you're using a curve tracer, you won't get much info from a meter. The meter gives you one point out of an infinite set. The curve tracer is far more telling.
G²
if they are shorted, then you will see a zero resistance from collector to emitter, or base to collector, or base to emitter.
Tony.
Tony.
Ohhhhh, no kidding. Now, just to be clear, I'll see a zero resistance from collector to emitter while I have the multimeter set to diode test, right? Or should I be using the Ohm setting? I know these are really basic questions, but I really appreciate the patience. This is really helping.
ohm setting will read zero (or close, ie less than 1ohm), diode test I think will read 0v drop (normally around 600mv if working), but try simply shorting the multimeter leads together in diode test mode to see what you get 🙂
Tony.
Tony.
- Design & Build
- Equipment & Tools
- New To Multimeters
