New to Full Range speakers...questions though
I know my questions have probably been answered many times,but....I am on a VERY slow dial-up system ....and have limited electricity so I need to be specific to narrow down the info. I apologize in advance.
To keep it simple...I want to build a simple set of full range speakers. They will be for a 12' x 12' room with 8' ceiling.
I like all kinds of music,jazz and blues are my favorite.
I am a carpenter/woodworker,so the cabinets are my forte.
My main question is...what drivers would you pick? I live in the USA,so thinking Fostex is the choice? I pretty much know nothing on the speaker part. I have read many threads but they confuse the heck out of me.
So i guess these are my questions.
#1 What driver?
#2 What size cabinet
#3 Do full range drivers need special wireing(caps,resistors,etc)...or just a simple direct connect ?
Sorry for the dumb questions,but i have to start somewhere.
Thanks.
#1 What driver?
You don't want to much driver... you have a small room. Efficiency would be a boon if you need to conserve power.
FE127, FE126e, FE167, FE166 would be a short list of Fostex. eN versions for a step up.
Once you choose a driver pick an enclosure (althou the available enclosures available may hekp you choose the driver)
Personally i try to avoid filters, but sometime people find BSC or other FR teaking networks useful.
dave
Thanks for the info Dave.
When you say filters...what is that? BSC or FR ? Like I said I know VERY little abut full range speakers.
Maybe filter is a cap or resistor ?
I can build any enclosure to suit my room,just wondering what driver and what size enclosure to go with. Also what style enclosure.
thanks
BSC = Baffle Step Compensation
Baffle Diffraction Step
FR = Frequency Response
A few examples of filters are to notch out peaks (they reduce the peak's visibility in a FR chart, but the resonance that causes the peak is still there, so sometimes the cure is worse than the problem, my approach is to try to reduce/kill these at the sotce by modifying the driver), broadly reduce the midrange so that it is closer in level to a falling top & bottom (using a high output impedance amplifier can have much the same effect), or flatten out a rising top end.
dave
there are other nice full rangers as well, don't limit yourself to Fostex... CSS, Markaudio, Tangband, ....
1 question that is important to make a choice is if you will have a fixed listening position or not? if you have, then a large driver will be OK, if not you'll might want to go for a smaller driver.
Thanks for the links and info. Looks like I have alot of reading to do. I really want to do this,but want a full understanding before I even start.
Egad! A full understanding! If that's the case then your situation is dire! I agree that a good understanding is helpful, but I find that I can only learn some things by taking the plunge and actually doing.
And if you can't go listen to any of the drivers before you build, then all you can do is read plenty and take your best guess.
For your size room, I can say that I would be looking at something like a Fonken or a Metronome with a Fostex FE127e. You can find threads here about those designs.
BTW, no driver is perfect; no design is perfect. It all comes down to what compromises are acceptable to you--and only your ears can tell you that.
Good luck, Jim
Just a quick note - and I'm sure you already know this - but baffle step and baffle diffraction are 2 very very different things.
Actually they are manifestions of the same phenomena, that express themselves in different ways depending on the frequency in question and the radius of the cabinet edge. At the extremes they express in distict ways, but in the middle you get a mix of both, with a continuous transition from one expresion to the other as the frequency is ramped up or down.
If you look at the curves of the baffle step phenomena, the ripples seen in less ideal enclosures is baffle diffraction.
dave
karlton,
If you want something that works well i.e. sounds very good, is not too picky about room placement, won't cost much, will involve a bit of carpenter skills, and requires no correction circuits (just 2 wires to the speaker terminals), then how about building a pair of Lotus BVR with the Mark Audio CHR-70 drivers. Drive them with a TA2020 digital amp which will put out at least 12 very clean watts per channel and this amp runs around 80% efficiency so you'd be using about 4W to 6W of electricity most of the time unless you crank it up loud (I assume you are running alternate/renewable energy sources). The drivers are around USD$100 a pair, the plans are here: http://homepage.mac.com/tlinespeakers/FH/download/Lotus-CHR70-map-130409.pdf I don't think this combination will disappoint, in fact the opposite, it will blow you out of the water. There are many good designs out there, but this one is impressing me every day and a great place to start, (and maybe finish) hence the reply to your post.
Ian.
