New Tangband Sub Drivers at Parts Express
Tang Band W57-1781 5" x 7" Poly Woofer
Parts-Express.com: Tang Band W57-1781 5" x 7" Poly Woofer | Tang Band W57-1781 5" x 7" woofer Poly cone Woofer tb speakers sub driver line array home theater computer speaker center channel car speaker oval
this Woofer is Certainly intreasting...parts-express lists it as a woofer,but tangband lists it as a Sub...the FR of 40-500 certainly means it couldnt be used in a standard 2 Way Effectively...being 5 x 7 being fitted into a factory car location is possible...a multimedia sub,or even a group in a Slim Tower speaker sounds good...3 mm excursion is not a whole lot but one should get decent bass from it...or at least i would hope,the 45 Dollar Price tag is abit high for my Tastes...at least for this particular woofer.
Tang Band W8-1747 8" Aluminum Cone Subwoofer
Parts-Express.com: Tang Band W8-1747 8" Aluminum Cone Subwoofer | Tang Band W8-1747 aluminum cone Tang Band TB Speakers subwoofer compact speaker
another intreasting woofer...the ribbed black aluminimum cone looks nice,and the 8 mm of X-Max sounds even better...but at 101 $?...sheesh!
Tang Band W8-1747A 8" Aluminum Cone Subwoofer
almost identical to the unit above..with the exception of the Cast Frame.
Tang Band WQ-1814S 12" Subwoofer
Parts-Express.com: Tang Band WQ-1814S 12" Subwoofer | Tang Band WQ-1814S 12" Woofer tb speakers sub driver neodymium line array home theater computer speaker car speaker in-wall subwoofer inwall sub shallow mount
a 12" with a very low profile...this unit would make for a very compact sub.
Tang Band WQ-1858 12" Aluminum Subwoofer
Parts-Express.com: Tang Band WQ-1858 12" Aluminum Subwoofer | Tang Band WQ-1858 12" subwoofer aluminum cone tb speakers sub driver line array home theater car speaker
12" Aluminum cone with Cast frame,and 13 mm Xmax....looks mighty tasty...even for almost 200 Bucks.
(i realize some of you have already seen these subs,and apologize if i wasted your time with this post.)
has anyone here used any of these Drivers?
I can't figure out whether the center is attached to the cone or the magnet system on the W8-1747A. Does any one know?
In a picture I now can't find of it, it looked as if the center cap wasn't part of the cone and there was a gap around it.
