• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
New Ta2020 Amp From Taiwan
here is a new class t amp ,based on ta2020.
the KINGREX T-20 AMP.
from 41hz audio
KINGREX T-20 AMP WEBPAGE
Alot of these manufactueres have good points and bad points, if they just refine it a little more with better quality workmanship thay can compete with the best of them, parts selection is pretty standard in the electronics industries, just a matter of selection and availability, everything else is up to the designer. I won't be surprise when these companies will rip open a Bel Cantos and copy it part per part soon.
"Kinda cool, I had not seen that one. Looks like all thru hole stuff, except the inductors. Layout look a little loose. Nice looking, tho.........."
It is all thru hole design include inductors,but now smt inductors.🙂
user can change it by themselves.😉
exciting!!! im interested of buying one of these cute class d ready made tripath amp, is the sounds better than the diy 41hz,diyparadise,autocostruire kits? and how about this one......
Little Dot T_100 Technical Specifications
Based on the Tripath TA2022 Class T
Continuous Maximum Output: 2x100W @ 4 ohms, 2x60 @ 8 ohms
Frequency Response: 9 hz - 93 Khz (+/- 5db)
THD+N: 0.02%
Micro-chip switching from four different sources
0 to -63 digital volume control (degree of distortion < 0.002%)
Samsung digital (VFD) display
Speaker surge protection: 200VA
Infrared remote control
Dimensions: 380L x 260W X 80H (millimeters, chassis only)
Weight: 7.5 kg
Tube Pre-stage Option with EF92/CV131 vacuum tubes!
abiedoodles said:
hi pano, did you got in hand the Little Dot T_100 do you recommend it?
I don't have one yet! But it should be soon. I've been working hard to get one.
My ears in China say that stock is low, they are hard to get. Also reports say that they have a hum problem that the factory has not been able to solve.
I hope neither is true! But hum I can fix, as long as I can get one.
