Just about completed the sub to go with the Jays http://members.optusnet.com.au/~gradds55/ARGOS/Jay's.html
the bottom part is the sub, the top part is a cupboard.
The whole sits on a 2.5ft tall concrete shelf.
Sub driver is Peerless 850845, with 200w SSS amp from WES.
box is 50 litres sealed
http://members.optusnet.com.au/~gradds55/jays_sub.jpg
Andy,
Those look great.
Regarding the covering, is that some rare wood veneer of some sort of lizard skin? 😕
Those look great.
Thanks guys. The fire did get a tad warm !!
but seriously, this finish is pretty easy to do, its a proprietory spray can.
http://www.plastikote.com/plastikote/homefash/template.jsp?searchcode=DEC&product=Cracklin
procedure:
undercoat first.
try to work with the surface horizontal
use a spray can for the undercolour (some cheaper cans don't work, but any of the Automotive type can sprays will. something to do with the solvents used I guess.)
then use the spray in the link, thick and even will give a good wide crackle effect. this is the tricky part, getting it thick and even
then spray coat 2 or 3 of spray clears
never use brush on enamel undercolour or clears, only sprays !!!
procedure:
undercoat first.
