New rebuild - 6F12P-6P45S Triode
My 6P36S PP amp with same 6F12P concertina driver works great however it's not trioded and have 5k opt. they rocks..
A gratuitous photo of the current amp. Not seen in the photo are the 6Z4 tubes sitting between the front and rear 6D22S tubes...
Also a copy of the current power supply schematic. Ignore "one for each output tube" since it's now using the AB-Q module.
Anyone else think those KMH capacitors are fake? :p They work fine but I'm pretty sure they don't make a KMH at 820uF/450V...
OH! And the idle power consumption is now 300W on the button, and 0.91 PF.
Ok. I made one more addition. A 0B3/VR90 VR tube to drop -170V to -90V so the amp doesn't take 150 seconds to bias up :)
Digikey's Scheme It doesn't have a symbol for a VR tube, so I used a zener symbol.
Hi.
How much power they produce and at what anode voltage in triode mode?
I know that in tetrode mode they work fine but the OPT must be about 1.6K anode to anode if i am right.
I just got 10 for 40 dollars and some sockets to use in place of the 829B just for fun!
Chris
