New PassDIY Headphone Amp (now available)
Case for amp
The Hammond 1455T2201 case has been mentioned a few times.
It looks to be a tight fit given the size of the PCB.
For those who used it, how did you find it? I'm a bit worried about
fitting in the various connectors.
Thanks,
Dennis
Hi Dennis,
It's a very tight fit but it works. I'm almost done with mine. My issue is more about routing wires especially if you want to avoid the transformer. I wasn't able to use an integrated IEC inlet/switch/fuse combo and had to use individual parts which meant several finicky small holes and more wires rather than one big hole and done.
At this point I have a list of suggestions for rev. 4 if Wayne or Jim ever decides they want to do one.
Graeme
