It's not as though you've got a choice in the matter, do you expect Lars would say anything less than "way better" for his new module?
I wouldn't even bother asking that kind of a question. From the looks of things though, it's likely to sound alot better than the 800XE.
It is still the culmination of what Lars has learnt from previous efforts, albeit a little simplified given that all the protection is now done with an MCU, which isn't at all bad.
Judge it for its own merit rather than against that of a non existant module, that you didn't even get to hear in stereo, or long enough for it to have broken in.
Well i really try to stay out of discussions that relate to LC Audio products. But i will say, that the 700XE was a really good amplifier, and it would be hard to make anything 'way better'. But i guess in high-end audio, 'just a little bit better' goes a long way too.
I'm sure many of us are looking forward to hearing Chris' verdict on Lars' new baby 😉 I am, anyways!
Really cool of Lars to let someone from the forum check out this new amp!!! if only all companies did the same... well DIY life would be easier!
/cdl
/cdl
I would be interested to getting one to compare with amps around here like cable shootouts I used to do. My other class D (class T) amp is not running because it's hard to troublshoot what's wrong with those tiny components that I soldered and had to put it aside for a while.
classd4sure said:It's not as though you've got a choice in the matter, do you expect Lars would say anything less than "way better" for his new module?
There are better ways to evaluate an amplifier than to label it "better" or "worse", that doesn't say very much.Even if I only listened to 700XE in mono and for only a few hours I become addicted to its performance and it's thereafter quite boring to listen to my 2.3 SE modules.
I just wanted to hear an opinion from someone who has listened to both 700XE and New ClassD and I thought the constructor himself would be the only one to tell what difference is between them.If the new class D is "a little better" that's good enough for me as would "almost as good" also be 😀 😉 😎
I am not at all interested in the 800XE for my private use.
Of course I'm gonna judge it for it's own merits when I get it but that doesn't keep me from reading your evaluations and comparitions
I'll be getting on that as soon as I can. In fact I think I'll start tomorrow by getting intimate with a file.. get some XLR's and an IEC in there. Then it'll just be a matter of interconnects... and I'm not above rigging up something scary for it... see how much magnet wire I have.. or maybe a few coat hangers 🙂
BTW, the PCB definately looks good. Needless to say, it's bugging the hell out of me not to be able to hear it when I have it right in front of me..... must... fix..see...blue.. LED... hmm.. I'm going to mess with the connectors on it now.
Hi AnzgarAnzgar said:How do you rate the sound as compared to the 700XE?
I'm very interested to know as I already listened to one channel of 700XE and it's hard to get a comparision betweeen them now as a 700XE can't be found.
It's hard to believe the new dvd module can sound even better...
Anzgar![]()
Please, stop making me feel nervous
... Chris's evaluation will be accurate and honest
... also, other than Lars, you are the only one who has heard the 700xe
It amazing that Lars is happy to use a single 200VA tranny, considering the amp can produce >200 watts per channel. He must certainly be confident 😱 Anzgar, I think that you can assume that is evidence in itself
Go Chris, get your posts happening, we are looking forward to them absolutely
rgds
Uh?
- hock :
a. The tarsal joint of the hind leg of a digitigrade quadruped, such as a horse, corresponding to the human ankle but bending in the opposite direction.
b. A joint in the leg of a domestic fowl similar to the hock of a quadruped.
c. A small cut of meat, especially ham, from the front or hind leg directly above the foot.
- hocked, hock·ing, hocks :
To disable by cutting the tendons of the hock; hamstring.
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
- hock :
Best regards,
Sander Sassen
Dictionary.com?
Should have scrolled down a little bit:
hock3 ( P ) Pronunciation Key (hk) Slang
tr.v. hocked, hock·ing, hocks
To pawn: hock a diamond ring.
n.
The state of being pawned: put the diamonds in hock.
The state of being in debt: thought we'd never get out of hock
n.
I can't help but wonder how many people just spit their beer/coffee out when they read that lol... I think it's this heat wave playing with my mind... bringing the wicked out of me.
Don't worry I didn't hock the amp, I'll try and rig something up to get an initial listening impression out soon, I'm short some wires and connectors right now.
classd4sure said:I can't help but wonder how many people just spit their beer/coffee out when they read that lol... I think it's this heat wave playing with my mind... bringing the wicked out of me.
Wasn't the amp delivered ready to play?Do you have to assemble it?A DIYer who doesn't have a pair of interconnections and some loudspeaker wires and connections at home?
Anzgar,
I don't have enough wires /connectors to keep two amps running at the same time. I can't cut the wires I do have to change the connectors back and forth or they'll be too short. So like I told you, I'm short some wires and connectors right now.
I'll tell you what though, you'll get to read my listening impressions before you get to hear your 700XE, acceptable? I think so.
No it wasnt' ready to play. I asked for XLR to drive it balanced and got RCA. It also was lacking a power cord/IEC. I'll be donating all those to it from my UCD demo project, but I'm not sacrificing my interconnects.
I'll be doing that with some cheap wire and 1/8" connector, and smaller gauge speaker wire I have kicking around.
That's the kind of listening test that's only worth so much..
I also plan on having to spend some time solving any grounding issues, but I expect this first impression by the end of the week.
Hopefully next month I'll be in a better situation to get more wires and connectors to do it whatever justice that I can.
classd4sure said:Anzgar,
II'll tell you what though, you'll get to read my listening impressions before you get to hear your 700XE, acceptable? I think so.
Well, let's hope that you can find a supplier of power cords and xlr connect cables soon.
I won't hear any 700XE at all again but a couple of NCD 1 modules
in due time.
May your god be with you
classd4sure said:I'll be doing that with some cheap wire and 1/8" connector, and smaller gauge speaker wire I have kicking around.
I think that's ok because I am more interested in the performance of the amp than I am in the performance of cables.And next month I will be listening to my own NCD1.
Does anyone know why there is a difference of 4-wire versus 6-wire for the power supply options? What's the relevance of either?
Yes:
4 wire is for use with a 42 - 0 - 42 - 0 transformer (also called 2 x 42 V secondary) - the most standard type.
6 wire is for use with a 42 - 0 - 42 - 0 + 15 - 0 transformer (also called 2 x 42 + 15V) More specialized type.
- Class D
- New Module by Lars Clausen
