Can you email me and then I'll tell you what I need to know.
Have just emailed you.
It seems like PA has done a good job.
Absolutely! The access time is now also lightning fast compared to previous.
'Just received your bookzine here in Oz, Jan. I'm suitably impressed with quality, content and delivery. There is some great stuff there and so best wishes for your continued publishing success.
Soo-Eee.
Jan, TY. (Q :does this mean i can't post cra. for the next couple of weeks?)
Mighty ZM received his porn ;
that means that I'm less dirty than jaCcoallahan ...... ?
Jacco just recovered from his first ETF night (having 'a' drink with Joachim, among others ) . I *think* he enjoys it.
jan didden
watch your precious Triodes from him !
he's going berserk very easily !!!!
YouTube - Berzerkers Vikings
stinius,
hi.
Hi
I guess this was your answer to my PM L O
Take care
Cheers
stinius
Just received my copy. Very interesting. To some extent it fills the gap left by Wireless World going off in a different direction.
The article on pentode noise raises interesting issues. It shows that in the audio range noise is dominated by 1/f, so partition noise (and shot noise) is not too important. Hence eliminating it with the "bestpentode" connection does not reduce total noise very much. The figures in the article seem to show that "bestpentode" is better than triode connection - I suspect that this is simply because the bias is slightly different. Lower current leads to lower noise.
Interestingly, I had the same idea a while ago but I never pursued it or published it so I can't claim precedence. I may have seen some whisper on the web about it somewhere. I would be surprised if nobody has thought of this before, as it is obvious to anyone who understands partition noise and has heard of the cascode.
The article does contain one minor mistake. On p49 the author says that it is obvious that the maximum improvement in noise for triode connection cannot exceed Ia/Ig2. He therefore doubts the claimed improvement of 6-14dB. If you work out the equivalent noise resistance such a large change is easily possible. This is because shot noise is heavily suppressed by the space charge, but partition noise is not suppressed at all. The reason he doesn't see such a big change in his measurements is that that are dominated by 1/f noise, which comes from a third source (i.e. neither shot or partition).
... letter to the editor..?
And yes, I would hope to be able to fill the void left by EW when it became a 'me too' EDN. And, trying to pick up where the AES left off 15 years ago. There's so much interesting material by very smart and knowledgeable designers that I want to document. Looking forward to your article...
jan didden
OK, but I couldn't find an email address in the mag. Is it on the website?
I would like to congratulate you on an excellent first edition. One minor point: could the diagrams be a bit larger? The text on them (e.g. voltage readings) are a bit small for me!
Thank you. And yes, I'll do better on the diagrams for the next issue. I'm new to this too .
There's several addresses on the website, but jan AT linearaudio DOT net gets my attention!
jan didden
Linear Audio Vol 1 is alive!
Well, it's been a lot of work (again) but the 2nd issue of Linear Audio (interestingly, called Volume 1 ) is now available on my linearaudio.net website.
I am so indebted to my authors, they again provided very interesting, amazing and surprising articles. Check out the article abstracts at the site.
Let me know what you think of it!
jan didden
jan didden
- General Interest
- Everything Else
- New Linear Audio publication!
