New HPA Products for 2015
Welcome to HPAs first Newsletter for 2015.
This year I hope to release a number of new products, this will include a pre-amplifier board, stand alone DC Servo, Balanced to Single Ended input amplifier to name a few.
To start off 2015 I have a couple of new products to show you.
The first one is the extreme version of the NXV1200L, this amplifier has been beefed up to the max with double the amount of output stage power supply filtering and improved and enlarged PCB layout.
The second new product is the NXV101L Signature Mono Block Amplifier.
This module uses a single pair of Exicon dual die lateral MOSFETs for much improved power output compared to the NXV101 R2 module. It also has improved power supply filtering with 12 x 4700uf 80 volt capacitors in is power supply. Signal to Noise Ratio has also been improved to over -112dB with respect to full output.
Power output for this module is up to 180 watts into 8 ohms and 300 watts into 4 ohm loads.
Visit holtonprecisionaudio.com for more information.
HPA-NXV1200LE Mono Block Amplifier
1200 Watts RMS into 4 Ohms
700 Watts Into 8 Ohms
64800uf of output stage DC filtering
THD+N = 0.05% SNR = -100dB
DC Servo to correct DC offset to less than 1mv
HPA-NXV101L Mono Block Amplifier
300 Watts RMS into 4 Ohms
200 Watts RMS Into 8 Ohms
56400uf of output stage DC filtering
THD+N = 0.005% SNR = -112.8dB
