New horn in PVC
GM:
relatively small CSA
CSA = mouth area?
According to the web site the tube structure is 14 ft long (=168")?! This is exceptionally long and implies an unrealistically low cut-off frequency for the driver used. You'd probably have much better performance by making it half the length - it certainly would be easier and cheaper to build.
It looks there's a compression chamber (CC) mated to a succession of smaller to larger diameter 90o PVC adapters make up the horn. If so you could model it as a BLH using King's excellent MathCad models (www.quarter-wave.com). The CC looks to be PVC pipe that's just larger than the outside diameter of the FE108EZ's frame (roughly 5") that immediately narrows down.
Assuming the throat is 0.5 Sd then you'll be looking for the first width to be close to 1.36" (diameter). You'll probably have to go to the plumbing store or home centre and see what sizes of PVC adapters they have and measure the length along the center. Then enter that info into the model and see how it will work. Note that the mouth area in the photos looks to be too small relative to the driver for good performance (I think that is what GM is referring to). To get a mouth area of at least 10 Sd or greater you'll need the PVC pipe to be more than roughly 14" in diameter.
Incidently the design is not like the B&W Nautilis mentioned. I believe that design is a TL with one end the size of the driver tapering down to a closed end.
No matter what it's an interesting looking design that may *just* work.
Holy Schnykies.
That's more tube than I'd ever want to deal with.
Yes there is some difference in the pipe widths
but is that necessary to calculate the line?
Can one diameter be used as in a straight TL?
And would extra length then go from quarter wave
as in the MJK calculations to half and beyond?
I'd be interested in making just one with the PVC
I have laying around from the last build.
