New High-End PC Audio products....
tX-USB : PCI USB Host Card for the Hi-End PC-Audio.
It is designed to get clean power and very accurate USB signal from PC inside.
To achive this goal, Special designed noise filter and Ultra low noise power circuit is used for this USB card.
If you use PC for your music listening player, tX-USB will give you Hi-END sound quality from your sound system
You can enjoy your listening experience will be better than ever.
Specification
- 2 USB port
- All ports can handle high-speed (480 Mbps), • full-speed (12 Mbps), and low-speed (1.5 Mbps)
- 32-bit 33 MHz host interface compliant with • PCI specification revision 2.2
- Supports 3.3 V PCI
- USB power on/off/open function
- Windows 2000 SP4, Windows XP SP2, Windows Vista, Windows 7, OS-X v10.x
dX-USB : USB to S/PDIF converter
dX-USB is connected to USB port of your PC. And It deliver High-End Audio quality Digital audio signal to your DAC through Coaxial, Optical, I2S output.
To achieve this goal, dx-USB is designed to use USB audio jitter cleaner, Ultra low noise power supply and Ultra low jitter clock which is developed by SOtM audio. and dx-USB also use special selected premium parts to maximize its performance.
The reason to use special circuit board design and parts is to reduce the jitter which is common problem of digital source player. You can find these solutions are now using on High-End audio device more and more.
dx-USB is the ultimate solution for your Hi-End quality PC-audio. And if you want to maximize the sound quality. We recommend you to use with tx-USB device.
Specification
- Output : Coaxial, Optical, I2S
- Sampling rate : 44.1KHz, 48KHz, 88.2KHz, 96KHz
- Bit-depth : 24bit, PCM
- USB power or External power input(+8Vdc ~ +12Vdc)
- Precision USB clock synchronizing PLL control function for USB audio jitter reduction
SATA & FAN filter: PC noise reduction
This products reduction power noise from HDD disk motor and FAN motor
Specification
- Input voltage : 12Vdc
- Input current : 2A
We are looking for dealer of this product.
If you are interested, Please contact sotm@sotm-audio.com or gp1601@naver.com
www.sotm-audio.com
Sorry! English home page is under construction... 🙂released
Specification
- 2 USB port
Specification
Specification
www.sotm-audio.com
