New EL34/6CA7/KT66 integrated amplifier
Our second new tube amplifier in May is available now. The circuit is 6SN7 SRPP drive EL34 class A single end. It's a simple EL34 single end circuit with pure class A sound. The output power is 7W. 6CA7 and KT66 are also suitable for this amplifier.
Dimension of the amp: 365W x 320D(inclu. binding posts and knobs) x 200H mm.
Net Weight: 11.8 KG
Can directly replace KT66 onto the amplifier. It is very easy to listen and experience different sound on the power tubes.
The output transformers are made with H10 EI 86 x 40 mm x 0.35mm steel cores. The primary impedance is 3.8K and secondary impedance is 0-4-8 ohms. The output power is 15W.
The power transformer is 200VA EI 96 x 60 x 0.35mm steel core. The output voltage is 290V-0-290V/250mA.
We can order the power transformers in other voltages like 100V, 110V and 230V, etc.
